TractorLinks.com
Order Ford 600 Parts Online
Re: 600 Ford Fuel tank valve:(Ideas for a BETTER replacement???
mike1972chev
03-13-2013 07:49:17
Thanks everyone.
Alan and Tony,I will be going the "rebuild it" route. I bet I can take the OLD one I pulled out and make it new again also?
I am wondering if a Viton O ring would be a BETTER choice to use????? (Works on my race stuff. )
showcrop
03-16-2013 08:41:50
 Re: 600 Ford Fuel tank valve:(Ideas for a BETTER replacement in reply to mike1972chev, 03-13-2013 07:49:17
There have been plenty of threads about these valves. I am very fortunate to have never had a problem with any of my three. Probably all three this year. I believe that the general consensus has been to stick with the original valve and use viton O-rings.
mike1972chev
03-16-2013 16:30:17
 Re: 600 Ford Fuel tank valve:(Ideas for a BETTER replacement in reply to showcrop, 03-16-2013 08:41:50
THAT is what I am doing. Took my valve apart this week end and I HAVE to "Order" Viton" seals this week. :( NO ONE caries VITON around me.
TONY JACOBS
03-13-2013 18:38:24
 Re: 600 Ford Fuel tank valve:(Ideas for a BETTER replacement??? in reply to mike1972chev, 03-13-2013 07:49:17
Hello Mike , Yes as Glen said use the Viton o ring I have been using them for years now with very good luck also . Yes you should be able to reuse the your old original one with out a problem , I do not buy any new ones at all I just keep swapping them out and rebuilding them , once they are in it only takes a minute to change the o ring in the tractor . Thanks Tony
GlenIdaho
03-13-2013 17:21:26
I used viton in mine and was told viton will withstand the new gas. So far no leaks.
mike1972chev
03-14-2013 03:23:06
 Re: 600 Ford Fuel tank valve:(Ideas for a BETTER replacement??? in reply to GlenIdaho, 03-13-2013 17:21:26
OK.LAST question,
What size is this O ring???? Reason I am asking is in case thos one I am pulling out is distorted and ruined enough not to be able to get a good measurement on it. (Probably can,but I am just asking.)
TONY JACOBS
03-14-2013 07:33:58
 Re: 600 Ford Fuel tank valve:(Ideas for a BETTER replacement??? in reply to mike1972chev, 03-14-2013 03:23:06
Hello Mike , The little o-ring on the needle valve is 4 mm. o.d. and 2 mm. i.d. the o-ring that seals valve to tank is 9/16 o.d. and .708 i.d. sometimes referred to as a #909 o-ring according to my notes dated April 2001 when I made my jig for the Bridgeport . Thanks Tony
