Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 641 questions
EarlyBronco
03-06-2013 16:14:36
Okay, well, got everything changed out but made a big mistake,
I pulled the sight glass off to change out the screen and gasket but, of course, a steady stream of gas started coming out, so i turned in a thumbscrew just above the sight glass, that I thought would stop the flow of gas (in a panic) so unfortunately I wasn't able to notice where it was originally.
Long story, long lol now it seems like it MAY have flooded (?) because I backed the thumb screw out to far(?) so it's gonna sit till tomm. Prior to it not starting (now), after I finished the tune up it fired up and seemed to run like a champ, but then it died (flooded (?)) and wouldn't start again.
I'm assuming the screw should be out around 2(?) turns?
Also, I pulled the bottom off the air filter assembly but I can't seem to get the air filter cartridge out from the bottom, any tricks/tips??
Keith Williams
03-07-2013 05:48:43
 Re: 641 questions in reply to EarlyBronco, 03-06-2013 16:14:36
"Also, I pulled the bottom off the air filter assembly but I can't seem to get the air filter cartridge out from the bottom, any tricks/tips?? "
STOP!!!
This is NOT a dry air cleaner! There should have been oil in the bottom of the cup you took off. You need to get a manual before you screw this up.
Keith
EarlyBronco
03-07-2013 06:03:41
 Re: 641 questions in reply to Keith Williams, 03-07-2013 05:48:43
Keith Williams said: (quoted from post at 06:48:43 03/07/13) "Also, I pulled the bottom off the air filter assembly but I can't seem to get the air filter cartridge out from the bottom, any tricks/tips??
STOP!!!
Keith
Yes, it's an oiled air filter system similar to many classic vehicles, and my John Deere 3010 tractor as well. yes there was oil in the bottom, however, the oil, instead of being black or a clean oil color was a nasty chunky brown color, I want to change the oil in the air filter system and I'd like to change the air filter cartridge as well since I'm finding a LOT if garbage and debris in it.
I also have a I&T shop manual FO-20, but its pretty much useless for basic tune ups or maintenance.
This post was edited by EarlyBronco at 06:14:58 03/07/13.
Keith Williams
03-07-2013 18:04:23
 Re: 641 questions in reply to EarlyBronco, 03-07-2013 06:03:41
Sorry if I was being a little harsh.
Many people just unbolt the air cleaner and then put it in a 5 gal bucket full of diesel to clean them up.
If you go to the other tractor site.
.com
club
Tractor
N
WWW.
Backward
Then go to the Manuals section, you can look at the operator's manual.
Keith
EarlyBronco
03-08-2013 07:25:59
 Re: 641 questions in reply to Keith Williams, 03-07-2013 18:04:23
No harm done, Keith. Thanks for the link! I've read the manual like 6 times lol TONS of good info in it!
But I know what you mean about the oil bath filter systems, my 1955 Buick Special still has it, I figure why change it? It works well and many aftermarket companies use the oil bath system (oily air filter) as their idea for an "oiled filter" not naming names (k&n) but there are many
