Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 2 spool valve on 631
[Show Entire Topic]  [Return to Forum]
soundguy
03-06-2013 11:02:34
108.112.247.178
fenders are generally the easiest.. you will be plumbing off the hyds port on the top cover? or a front or rear pump? keep those plumbing lines in mind.
some loader frames have the spool on an uprigth frame mount about even or a lil forward of the steering wheel.. either side depending on make.
you could propably fab up an angle iron bracket and attack to the right side of the hood, near the steering wheel. that will put it up and out of the way of the steering arm and not prevent entry/exit.. also won't be in the way of the air cleaner which has a few bits under the left side of the hood in that area.
I'd use large fender washers on the backside of the hood.. or a short strip of flat bar stock or more angle to back up the bolts.. won't take much.
on my naa i mounted to right fender, running lines ove rthe axle trumpet and upthe side to keep them out of the way.. on my 850 they are on the right side of hte steering wheel on the frame of my superior loader.
I think if you try to make a trans bracket.. you will run into problems witht he steering arm..same using running board mounts.
lastly.. both R and L side of the tractor bellhousing has flats and tapped holes. an angle iron bracket could be rigged up to attach there then travel up and then back a bit to make a perch for your valve cluster. .. could make a small stabilizer to the hood with small stock.
i'd got with fender first ( not what you want ).. and then 50/50 on the hood or the bellhousing mounts.
most of my machine already have a frame in the bellhousing mounts meaning hood.. or attaching to what already inthe bellhousing mounts. etc.
good luck
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
