Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford NAA Parts Online
Re: Ford NAA-Trouble Running
soundguy
03-06-2013 07:21:08
still sound slike gas flow to me.
open drain at bottom of the carb and set a LARGE GLASS JAR DOWN THERE AND JUST LET HER PEE.
give it a good minute.. see what happens.
the fact that she stats back up after stall means it probably wasn't a loss of sparkies.. unless you have an ignition switch with loose guts that kills spark from the key jiggling in it.. etc.
Gonefishn
03-06-2013 09:43:01
 Re: Ford NAA-Trouble Running in reply to soundguy, 03-06-2013 07:21:08
I sat a container below the carb and let about a quart run from the plug, about a minute. There was no change whether the gas cap was on or off.
When I rebuilt the carb I put in a new float. There was not much adjustment needed. I have it set at about 1/4 inch. I used a 14 drill bit for spacing. I was told that the float may need to be set even closer. It does act as though it is losing fuel. I do not want to touch the float without maybe changing the condenser first.
soundguy
03-06-2013 10:26:01
 Re: Ford NAA-Trouble Running in reply to Gonefishn, 03-06-2013 09:43:01
might as well change the tire too!
shotgun parts guessing and changing will just empty your pockets.
your call.
condensors have 2 failure modes.. open and short.
open condensors allow points to burn. once that happens.. you won't restart untill you repalce or dress the points.
not yer problem.
shorted condensors kill spark by shorting the points. Shorted condensors are probably the rarest form of failure.. and generally it is a thermal issue... thermal issues are not immediate onset.. nor immediate dissipation. If you have a stall and you can restart 5 seconds later.. it's extremely unlikely that your condensor shorted and then fast healed.
Alsys east to check points opening and closing, externally, with a test lamp hooekd to the feedthru post on the dizzy.. blinking lamp means points are opening and closing and condensor is NOT shorted.
ps.. check them muffler bearings while you are at it.
