Ok,..Got the wheel removed, and the only problem I have now is there is no knockout plug in the brake backing plate! Shop manual says to drill out a 1 inch hole in the brake backing plate directly behind the wheel bolt circle.
Now here are the questions:
If I do drill out a 1 inch hole,..do I need to get a backing plug,..book says nothing about that?
Where do I drill the hole? I have two clearances between retainers of some sort at the top and at the bottom,..would that bottom clearance be the best place?
Am I hosed and I have to remove the axle shaft from the axle housing?
Thanks for any help here,..the shop manual is so "in general" and the pictures are so limited.
