TractorLinks.com
Order Ford 5000 Parts Online
Re: Help with ford 5000 serial number
Fordfarmer
03-05-2013 06:11:12
5D4C is the date (unit) code. 1965, April 4, 3rd shift. Can't help with the D138. B040788 is the serial number, with the B indicating a Basildon-
built unit.
Sean in PA
03-06-2013 15:27:12
 Re: Help with ford 5000 serial number in reply to Fordfarmer, 03-05-2013 06:11:12
[quote="Shetland Sheepdog"](quoted from post at 18:13:14 03/06/13)
I'm pretty sure that they had already switched over to the x600 production (2600, 3600, 4600, 5600, etc.) by April of 1975. Plus the serial number is B040788, and any thousand series serial number that starts with a zero after the letter is a very low serial number regardless of which plant it was assembled at. If that serial number was a 1975 serial number, that would mean that they only produced 40,000 tractors at the Basildon plant in 10 years of production.
jlmoceri
03-05-2013 06:47:22
thanks for the info. I wonder how to figure out the D138. I would like to know everything about it. The pto, chassis etc.
McBride
03-05-2013 07:31:48
 Re: Help with ford 5000 serial number in reply to jlmoceri, 03-05-2013 06:47:22
The 5D4C is 5-1965, D-April, 4-4th Day and C-Afternoon Shift.
The B040788 is the serial number B for built in Basildon.
The other number should be for Chassis, Fuel, Pto and Transmission in that order but the number D138 is not a good number for my book codes.
Sorry.
Here is some examples:
E1013C
E=Model 5000
10=Agricultural
1=Diesel
3=Live 540 rpm pto
C= 8 speed transmission
E4021A
E=5000
40=Utility
2=Gas
1=No PTO
A=4Speed Transmission
jlmoceri
03-06-2013 15:07:22
 Re: Help with ford 5000 serial number in reply to McBride, 03-05-2013 07:31:48
jlmoceri
03-06-2013 15:10:03
 Re: Help with ford 5000 serial number in reply to jlmoceri, 03-06-2013 15:07:22
maybe that will pic will help ford farmer. if it doesn't hopefully you can tell me another way to figure it out
Fordfarmer
03-06-2013 15:41:43
 Re: Help with ford 5000 serial number in reply to jlmoceri, 03-06-2013 15:10:03
I meant of the whole tractor... We'd be able to tell chassis type (utility, row crop, etc.), transmission, maybe PTO. But I think in 1965, it was utility only (RC came out in '67), with the 8-speed or Select-O-Speed. SOS was independent PTO, as were most (all?) 8-speeds. Not sure if the 5000's were available without independent PTO... My '67 sales literature only lists independent PTO.
jlmoceri
03-06-2013 13:21:19
Thanks guys. I'll do some more checking and try figure out the chassis and other stuff.
Fordfarmer
03-06-2013 13:26:10
 Re: Help with ford 5000 serial number in reply to jlmoceri, 03-06-2013 13:21:19
Can you post a picture of it? We could probably tell you at least most of the info on it.
