Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4000 Parts Online
Re: ford 4000 backhoe
showcrop
02-28-2013 05:09:50
There is a useful trick for separation of the pan from the bolster. You will need to remove the radiator and disconnect oil coolers, steering lines etc. Then you remove two of the bolts that hold the bolster to the pan, and replace them with two that are about four inches longer. Then you remove the other two and then you can slide the bolster ahead a little and out of the way. Be careful with the washers between the bolster and pan, they are SHIMS. The rear seal is at the back end of the motor. As Rod says it is probably due to fail also, so if you have the time it would be good to replace it as well. Both jobs require some jacking. and blocking for safety. Use a jack to lower the oil pan. IT IS HEAVY. Most people roll the rear away from the front. Get a trailer jack and fabricate a bracket that will enable you to attach the jack to the side of the rear housing for stability and ease of rolling.
