Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: ford 4000 backhoe
[Show Entire Topic]  [Return to Forum]
decatur
02-28-2013 03:48:21
184.1.133.13
so how much is involved in splitting the bolster from the engine? does it require alot of knowledge and heavy work? is the rear seal located in between the bolster and engine? just trying to figure this out? thx
[Reply]   [No Email]
RodInNS
02-28-2013 06:34:02
216.118.158.123
 Re: ford 4000 backhoe in reply to decatur, 02-28-2013 03:48:21
On a TLB I suppose there is a fair bit of work, moreso given you alredy have the head off... You need to be able to move the engine away from the transmission about a foot... or at least 6" and lift it out.
It would be a lot easier if the loader and hoe were already off.
No doubt it can be blocked and the subframe removed if necessary but nothing will be easy.
Mabey you want to revaluate wether or not you want to rering it now. I'm just saying realistically... if you're going to get into rings... you probably want to look at the bores and probably sleeve that block if it's suspect, then do the remainder of the bottom end.
Rod
[Reply]  [No Email]
showcrop
02-28-2013 05:09:50
75.67.231.80
There is a useful trick for separation of the pan from the bolster. You will need to remove the radiator and disconnect oil coolers, steering lines etc. Then you remove two of the bolts that hold the bolster to the pan, and replace them with two that are about four inches longer. Then you remove the other two and then you can slide the bolster ahead a little and out of the way. Be careful with the washers between the bolster and pan, they are SHIMS. The rear seal is at the back end of the motor. As Rod says it is probably due to fail also, so if you have the time it would be good to replace it as well. Both jobs require some jacking. and blocking for safety. Use a jack to lower the oil pan. IT IS HEAVY. Most people roll the rear away from the front. Get a trailer jack and fabricate a bracket that will enable you to attach the jack to the side of the rear housing for stability and ease of rolling.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
