Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: SOS question (More Info)
jeff pk
02-27-2013 21:33:45
I will try that if the band adjustment doesn"t work. Can that pin be replaced with a suitable sized drill bit cut to fit? I"m assuming that the part is not available from the store. Thanks for pointing me in this direction--- I would never have figured this out. I don"t know what any of these components do, except that when they"re all together and working properly they move my tractor...
02-28-2013 06:57:36
 Re: SOS question (More Info) in reply to jeff pk, 02-27-2013 21:33:45
Rwplacing the pin is straight forward. You should be able to complete the job in a couple of hours or less.
Be careful removing the interlock assembly. It will likely be well stuck to the transmission case. DO NOT drive a wedge between the cover and the case at a tab or ear. Doing so can break off part of the cast cover.
You will need to order a gasket from CNH. Order the pin at the same time.
jeff pk
02-28-2013 09:30:34
 Re: SOS question (More Info) in reply to Dean, 02-28-2013 06:57:36
Thanks Dean. You wouldn't have a part number for that pin would you? Found the cover gasket number, but can't seem to isolate the pin...
Larry NCKS
02-28-2013 09:53:07
 Re: SOS question (More Info) in reply to jeff pk, 02-28-2013 09:30:34
Jeff - did you read my last response? It was ahead of Dean's and included both the gasket number and the pin number! LOOK AGAIN!
jeff pk
02-28-2013 09:57:39
 Re: SOS question (More Info) in reply to Larry NCKS, 02-28-2013 09:53:07
Yes, I just saw that! Thanks Larry.
