| Ford Tractors Discussion Forum |
Topic: Checking the Hydraulic Fluid Level on an 861 D
[Return to Forum]
| Author |
[Modern View]
| Marc_FL
02-26-2013 16:26:30
174.131.36.36
I've been having problems lately that the 3 point won't lift. Add hydraulic oil but the tractor did not have a dip-stick. The last time I checked recently I added UTF oil because it looked low filled it to a level folks 'thought' was good. The lift worked great. Now today almost the same problem. I'm not sure if I'm putting in enough 'hard to tell' 'without a dip stick'. Thought there would be a leak. Slight drip on the bottom of the tractor after it ran. Wiped it off and let it sit 'no leak detected'. My thinking here if there was a big leak it there would be big puddle of hydraulic oil on the ground. None detected on the ground or the bottom of the tractor. Simply maybe I'm not putting enough in.. My question is how can you tell the right amount without a dip stick? Any ideas would be appreciated. Thanks! |
| soundguy
02-27-2013 05:52:14
107.41.163.65
Re: Checking the Hydraulic Fluid Level on an 861 D in reply to Marc_FL, 02-26-2013 16:26:30
| | you can safely put up to 3g of oil in that hyd sump.. I have laoders using that much to keep it from sucking dry with SA lift cyls extended. I like about 2g in general. if it's loosing prime as stated.. remov ethe plug from the pump and put in a pip threaded brass petcock... it's a redneck bandaid.. but works. can loosen to bleed each day... till you get it fixed correctly. |
| DaveH IA
02-27-2013 04:36:27
71.7.102.199
| Saw one with a 20 penny nail in it - if you have oil on the end you are close- |
| Dean
02-26-2013 21:11:14
152.216.3.5
| | You cannot but overfilling the hydraulic sump a reasonable amount will have no adverse effect. It is a routine occurrence for the hydrayulic sump to be overfilled when the tractor is equipped with fully retracted external cylinders. Dean |
| sixbales
02-26-2013 17:30:00
70.248.182.232
| An 861 is supposed to have a dipstick for the rear differential/hydraulic reservoir by the PTO shift lever. The filler cap is on top of the rear differential center housing behind the seat. |
| Larry NCKS
02-27-2013 05:42:34
70.195.0.108
Re: Checking the Hydraulic Fluid Level on an 861 D in reply to sixbales, 02-26-2013 17:30:00
| sixbales said: (quoted from post at 20:30:00 02/26/13) An 861 is supposed to have a dipstick for the rear differential/hydraulic reservoir by the PTO shift lever. The filler cap is on top of the rear differential center housing behind the seat. |
Incorrect! The dipstick is for the hydraulic reservoir only! The filler plug is under the seat. The differential/rear axle is an entirely different reservoir and has a level plug on the left trumpet.
Marc - you can buy a new dipstick from NH. My guess though, is that you're losing prime in your pump. Remove the front plug on the top of the pump and look in. If it is not full, crank (don't start) the tractor until it is full. Replace the plug and it'll work fine until the next time it loses prime. If this is your problem, and if it persists, a pump overhaul is in order.
This post was edited by Larry NCKS at 05:47:04 02/27/13. |
| 861D fluid level
02-27-2013 09:34:09
50.36.84.218
Re: Checking the Hydraulic Fluid Level on an 861 D in reply to Larry NCKS, 02-27-2013 05:42:34
| Might check your transmission level if your fluid is disappearing from the hydraulic sump. Might be pressure tube or bad PTO support seal. I'm certainly no expert but I have the same situation. I have purchased parts to correct but have another project going right now. I just drain excess off transmission and put it back in the hydraulic sump. I can run the tractor for a couple hours with no problem before lift starts acting up due to lower fluid level. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
