Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Ford 3000 rear axle
[Show Entire Topic]  [Return to Forum]
Jetbird
02-22-2013 19:56:40
68.191.76.117
Hi, I did this job on my '68 3400 last summer. I was able to remove the nut by hitting it with a hammer and cold chisel to turn it. It cut into the nut a little, but not too bad. Once I had the nut off, I took it to a shop and the guy pressed the axles out for me. He didn't have to remove any studs, just blocked it up with some steel scraps to get it in position. On assembly, I used an automotive wheel bearing socket that I bought from amazon . com for about 10 bucks. I cut the back out of the socket, and also had to cut some slits in the sides since the socket was made for a hex nut with more rounded corners. I slipped the bearing onto the axle enough to get the nut started, then used the nut to drive the bearing home. I turned the nut using a big pipe wrench on the socket, and a prybar wedged between two lug bolts on the hub. I cranked it down as hard as I could. No torque wrench, but I tried to tighten it further with my hammer and chisel method and it didn't budge so it was at least as tight as it was before I started. No problems with it so far. You can find the socket I used on amazon under "Powerbuilt 647068 2-3/4-Inch 6-Point Rounded Hex Wheel Bearing Locknut Socket". Worked for me. Best of luck!
This post was edited by Jetbird at 18:20:41 02/23/13.
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
