Purplehaze
New User
I have an 801 ford powermaster and I"m having trouble with the fuel pump and governor. I went to start up the 801 today and she turned over but then would slowly die down. I sprayed some starting fluid in the air filter housing and it would use it and then slowly die down again... It is also blowing more smoke than it should and my guess is fuel is leaking through the pump into the crankcase, causing it to smoke badly. The governor is messed up, not sure what"s wrong with it but every time I use the tractor, the first 30 minutes or so it will randomly rev up. Not sure what is causing this in the governor? Any help with my problems is greatly appreciated. - Joel
