Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 801 Parts Online
Re: Ford 801 powermaster
Texas!
02-22-2013 13:21:13
You have a RoosaMaster (now Stanadyne) injector pump. They are famous for allowing fuel to leak past seals on the driveshaft into the crankcase. They are also famous for the return line under the rocker arm cover to crack and allow fuel to drain into the oil. They have a plastic governor ring inside the pump that is famous for crumbling into pieces and the engine RPM becomes uncontrollable.
All of these are easy fixes. Replace the seals and confirm that the return line is not cracked. There is a kit that eliminates the plastic governor ring but you have to disassemble the pump to install the kit.
Maybe it's time to take the pump and injectors to a diesel shop.
