Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Ford 641 Not Starting
[Show Entire Topic]  [Return to Forum]
Texas!
02-22-2013 11:08:07
207.13.78.201
Before you attempt to bypass the solenoid make sure the trans is in Neutral. Then confirm the trans is in Neutral. Then verify that the trans is in Neutral. Now that you know the trans is in Neutral you can bypass the solenoid by connecting one end of a jumper cable (red or black- it doesn't matter) to the battery terminal that is connected to one of the large solenoid posts. If your tractor is still 6V, Positive ground it will be the Negative post. If someone has done a 12V conversion it will probably be the Positive post. Then touch the other end of this same jumper cable to the post on the starter. Does it turn over?
[Reply]   [No Email]
Ralph208
02-22-2013 11:41:22
64.12.116.9
Re: Ford 641 Not Starting in reply to Texas!, 02-22-2013 11:08:07
This tractor has a 6 Volt System. I should have included that. Also the tractor has been used weekly and was parked for about six weeks. Went out to start it and all I got was the clicking of the solenoid.
Will give the bypass a try.
Ralph
  [Reply]  [No Email]
Ralph208
02-22-2013 13:23:23
64.12.116.9
Re: Ford 641 Not Starting in reply to Ralph208, 02-22-2013 11:41:22
Gave the bypass a try....all I got was some spark off the starter while making the connection. It did not turn the motor.
Ralph
  [Reply]  [No Email]
old
02-22-2013 13:30:35
209.86.226.19
Re: Ford 641 Not Starting in reply to Ralph208, 02-22-2013 13:23:23
Pull the starter off then use jumper cables and try to spin it over by hooking up a good ground to the frame of the starter then touch the other cable end to the stud for the solenoid and see if it spins over that way. If it does fair chance you have bad connections where your battery cables hook up or a poor ground. If it does not spin over take it to an auto parts store and let them check it most do it for free.
  [Reply]  [No Email]
Texas!
02-22-2013 13:23:16
207.13.78.201
On a 6V system it is imperative that all wiring connections including grounds be shiny bright and tight. You may just have a dirty/loose connection or a weak battery.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
