Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Roosa Master Pump Need Max Fuel Delivery Setting
[Show Entire Topic]  [Return to Forum]
Dieseltech
02-21-2013 19:32:22
199.16.223.2
List the complete DBGVCC 429 xxxx and I will look up the RR spec. One I just did was 1.960.
[Reply]   [No Email]
frazier2cyl
02-21-2013 19:58:16
71.96.130.130
 Re: Roosa Master Pump Need Max Fuel Delivery Setting in reply to Dieseltech, 02-21-2013 19:32:22
DBGVCC429 5AJ
[Reply]  [No Email]
Dieseltech
02-22-2013 04:50:23
75.146.127.109
 Re: Roosa Master Pump Need Max Fuel Delivery Setting in reply to frazier2cyl, 02-21-2013 19:58:16
Roller setting is 1.960.
[Reply]  [No Email]
frazier2cyl
02-22-2013 06:07:04
71.96.130.130
 Re: Roosa Master Pump Need Max Fuel Delivery Setting in reply to Dieseltech, 02-22-2013 04:50:23
Diesel tech. I have repaired several of these simple roosa pumps and cav pumps. I always check the max fuel setting while I'm there and adjust it accordingly. Here is my question. I plan on adding a turbo to this tractor. If I was wanting to richen the pump up a little is this where the adjustment would be made. Would I go up or down on the max fuel setting . Or should I just leave it alone.
[Reply]  [No Email]
Dieseltech
02-22-2013 12:47:35
98.206.80.148
 Re: Roosa Master Pump Need Max Fuel Delivery Setting in reply to frazier2cyl, 02-22-2013 06:07:04
How much power increase are you looking for with the turbo added? 10 to 15% MAY be OK on this engine. Just my opinion, but any more on this engine you may drive over the crank. I had one apart, had a spun rod bearing. Also had a Standard Motors 23C apart for overhaul, it had much stronger rods. Was planning on adding a turbo to the 172, but parted it out instead. Still thinking of charging the Ferguson though. I would tighten your leaf spring for 1.975 RR setting. Then watch boost on PTO dyno and see what you have.
[Reply]  [No Email]
showcrop
02-22-2013 05:27:23
75.67.231.80
Is that where you are setting mine? or just a little more?
[Reply]  [No Email]
showcrop
02-22-2013 05:27:12
75.67.231.80
[Reply]  [No Email]
Dieseltech
02-22-2013 13:47:30
199.16.223.2
 Re: Roosa Master Pump Need Max Fuel Delivery Setting in reply to showcrop, 02-22-2013 05:27:12
I plan to get your pump and injectors finished this weekend to send back monday if all goes as I hope. Will be set up slightly, but not for a turbo.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
