TractorLinks.com
Show Parts for Model:
Re: fordson super 3ph
JMOR
02-21-2013 06:14:26
Quoting Removed, click Modern View to seeYou may KNOW better than I do, but it seems to me that the "dump" circuit is independent of the unloader valve, so proper mechanical positioning of control valve should open the dump path & lower the arms. On the long shot that the pump output can flow more than the dump path, then 'stuck in lift position unloader' might keep arms up, but even then they should drop at engine/pump stop.
brian stanek
02-21-2013 09:54:41
 Re: fordson super 3ph in reply to JMOR, 02-21-2013 06:14:26
well it seems even with the tractor shut off and me standing on the arms they will not go down, tried the control arms in various positions? there is some kind of a unit on top of the housing with a control valve and hydraulic hoses with couplers from it, was wandering if it is affecting the lift part?
JMOR
02-21-2013 10:13:09
 Re: fordson super 3ph in reply to brian stanek, 02-21-2013 09:54:41
Quoting Removed, click Modern View to seeVery well could be.......operate that valve and see it all is then well with your lift.
