TractorLinks.com
Order Ford NAA Parts Online
Re: Ford NAA-311006 Solenoid
Gonefishn
02-19-2013 11:18:49
This was going to be my next step. I recently replaced the old 6V solenoid with the 12V(previously converted to 12V system). I have one small terminal connected to the key switch and the other connected to ground. When I check the voltage at the small hot terminal, I have over 12V, but the solenoid does not close. I have checked my connections and they are good.
Texas!
02-19-2013 13:46:47
 Re: Ford NAA-311006 Solenoid in reply to Gonefishn, 02-19-2013 11:18:49
There"s lots of chinese junk out there now. This same problem shows up regularly on the Mustang forums.
soundguy
02-19-2013 11:28:27
do you actually have the correct solenoid, and not a bypass slenoid, and have the bypass side hooked up?
try this.
hookup bat to both the big posts.
hook ground to case
probe either small post with wire from bat.
if it clicks.. it's the wrong one.
if not, try bat / ground on the small post.. ethen reverse them.
post back observations
