TractorLinks.com
Order Ford 801 Parts Online
Re: 801 Engine Races
Will Gumbert
02-19-2013 10:14:17
I had a similar problem after I rebuilt the TSX-769 for my tractor, although not quite as drastic. For the goverenor to work right the throttle shaft on the carb must turn freely and easily with no resistance. If you replaced the throttle shaft as part of the rebuild, maybe yours was like mine in that the flat on the shaft was not machined right (foreign junk!) and the throttle plate sat down too deeply in the carb and at a slight angle. This caused the throttle to stick so when running the engine and pulling back on the throttle nothing would happen at first as you pulled on the governor spring, then further movement would cause it to jump making the engine race. I couldn't make this part work I had to put the old shaft back in. Suggest you check yours with all the linkage disconnected from the carb. -Will
