Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 861 Parts Online
Re: 861 Front Axle Pin Removal
GlenIdaho
02-18-2013 15:27:23
I did something similar. Using bar stock I welded a 11/16 (OD) nut to the center of it and used an impact wrench to remove it. Worked good, but this was also after a good soaking and a little heat. My pin was VERY stuck as some are.
petra79
02-18-2013 16:27:37
 Re: 861 Front Axle Pin Removal in reply to GlenIdaho, 02-18-2013 15:27:23
Same here. I also first ran the other way to tighten (just a tad), then reverse. It helps crack the rust loose.
Copyright © 1997-2015 Yesterday's Tractor Co.
