Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: generator headache on 2000 series Ford
[Return to Forum]
Shoepeg
02-18-2013 14:13:47
166.205.68.42
I apologize for repetition if this has already been covered by you guys but this is my problem. If the generator light stays on while the motor is running, that means the generator is not charging? I just bought a new battery. Tractor cranks and runs fine but the generator light stays on. It has the Lucas type generator.
[Reply]   [No Email]
Will Gumbert
02-18-2013 14:53:34
74.110.74.48
Re: generator headache on 2000 series Ford in reply to Shoepeg, 02-18-2013 14:13:47
Yes, that is an indication that the charging system is not working, but to be sure you should do some checks. You didn't say if this problem suddenly appeared on a tractor that was working OK, or what year the tractor is or whether it is 6V or 12V but I'll assume it's 12V and the following generally applies. With the tractor running at about 1000rpm, use an analog volt meter to check the voltage across the battery terminals (digital meters may not show a stable reading). If it's not at least 13V then there's a problem. Next thing would be to make sure the wiring is correct and intact and that the generator and battery are well grounded. You may need to refer to a wiring diagram, do you have access to one? It's always best to diagnose things first, then post back with more info. -Will
  [Reply]  [No Email]
Shoepeg
02-18-2013 15:32:32
166.205.68.16
Re: generator headache on 2000 series Ford in reply to Will Gumbert, 02-18-2013 14:53:34
Sorry about that! It's a 1977 year and yes it is a 12V system. I'll be checking the wiring over the next few days. The chipmunks down here love chewing wires! I'll get a meter on the battery also and post back. I really appreciate the help, Will!
  [Reply]  [No Email]
soundguy
02-19-2013 05:51:38
107.41.51.62
Re: generator headache on 2000 series Ford in reply to Shoepeg, 02-18-2013 15:32:32
i agree.. 77 should be a 2600 with an alternator.
double check what you have and get back to uss.
if it is a genny.. try polarizing it and see what happens.
jump bat to field.
  [Reply]  [No Email]
Sean in PA
02-18-2013 18:46:49
71.224.102.32
If it's a 1977 tractor, then it's not a 2000, and it didn't come from the factory with a generator. They stopped making the 2000 and started making the 2600 as its replacement in 1975, and switched from a generator to an alternator at the same time.
  [Reply]  [No Email]
Shoepeg
02-19-2013 06:27:19
166.205.68.20
Re: generator headache on 2000 series Ford in reply to Sean in PA, 02-18-2013 18:46:49
It has the 2000 series decals so I guess it's a 1974. I was told
it was a 77. Guess he didn't know what he was talking about
and I never checked the casting numbers. I just took his
word for it. It does have a generator however and an
external voltage reg. I'll be trouble shooting some more on it
later this week using some of ya'lls advice and post back. I
do appreciate everything guys.
  [Reply]  [No Email]
tater_51
02-18-2013 15:58:06
50.36.84.218
I'll have to do the same. Just changed the bulb and found that my light stays on as well. It's a 861D. The PO had converted to an alternator, I think a single wire installation, so I don't know if that could be a problem source. I will check the voltage across the battery while running.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
