TractorLinks.com
Order Ford 4000 Parts Online
Re: 4000 ford troubleshooting
Larry NCKS
02-17-2013 14:11:54
By skip, I'm guessing you're saying it has what I call a miss. If that is the case, you have an injector that isn't up to snuff or a cylinder low on compression.
tonyw
02-17-2013 14:14:18
 Re: 4000 ford troubleshooting in reply to Larry NCKS, 02-17-2013 14:11:54
i dont think the compression is bad i was already leaning toward injector but wasnt sure that would cause that. Would it be best to replace the nozzle or to replace the entire inector
Larry NCKS
02-17-2013 22:55:15
 Re: 4000 ford troubleshooting in reply to tonyw, 02-17-2013 14:14:18
Pull the injector in question and have it tested. Let the diesel shop make recommendations.
It likely would not be a bad idea to have all four tested. If the atomization is weak or the spray pattern is off, it can cause the missfire, especially when the engine is first fired and not warmed up.
Shoepeg
02-17-2013 17:23:51
Bad injector
gatchelguy
02-17-2013 15:29:20
Replacing the nozzle will require adjusting the injector pop off pressure. Are you equipped to do that?
