Neil 4x4
New User
Can someone help me . how much oil goes in the back end of a ford 4.000 i am going to put in 15-30 oil thanks neil
If it's a 3-cylinder, it takes 7 quarts in the
crankcase (with filter change), 13.8 quarts in the
transmission, and either 26.25 ('65 through 7-19-
68)or 33.9 (7-20-68 and later) quarts in the
hydraulics and rear end. I would NOT use 15w40 in
the rear end (or tranny). Use 134D compatible
hydraulic/transmission oil.
as has been said.. if a 3 cyl.. it's 65+
perhaps you should post a pic of your machine.
you are completely unfamiliar with them.
use only a utf fluid inthe rear / hyds.
