6600 serial decode for me please
C496134 is a 1976 serial number. A little less than a third of the way thrugh the serisa number range for that year, so I would guess March.
If the 6A21C was from the other side of the transmission than the serial number, then the transmission was assembled on January 21, 1976 during the afternoon shift. The tractor was usually assembled a couple of monmths after the individual components, like the engine and transmission were assembled, so a build date for the tractor in March of 1976 is probably about right.
If you could post the other 2 numbers on the same side as the serial number we could give you the exact date the tractor rolled off of the assembly line, plus the details on the trans and PTO types as well.
