Back Pressure Valve on a NAA Hydraulics
KCTractors
Location
Central Wi
Working on a NAA hydraulic system. The 3pt will not do anything, so I took the top cover off after taking the acorn nut off, when I did that I seen the back pressure valve was turned all the way out, so would that be my trouble with the system? Is that just a O-ring that would sit in the cylinder housing or is it something else? When I put the top cover on, I just turn in the pressure valve till it comes against the O-ring , right! I think the cam follower pin is worn to, so how do I get pin out? I just bought the tractor knowing that the hydraulics did not work
