| Ford Tractors Discussion Forum |
Topic: Re: NAA steering shaft
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Nilram
02-13-2013 16:11:12
208.123.15.242
Thanks for the advice on my steering problem. I was able to weld it but on the test run I found that I have 1/3 of a turn of play in the wheel. Is there a way of taking up this much "play" without taking it all apart again? Thanks |
| soundguy
02-14-2013 05:20:05
107.41.182.34
Re: NAA steering shaft in reply to Nilram, 02-13-2013 16:11:12
| | when you had it apart, that was the time to R&R the thrust bearings and adjust the shim stack. if the steering wheel rises or falls slightly as you turn the wheel lock to lock with the front end jacked up.. you need to repalce those thrust bearings. if no rise / fall, check your sector adjustment.. you can do those externally.. loosent he sector stud lock nuts and then adjust the sector studs in with a large screwdriver till they just snug up.. don't try torquing them.. they will make the steering stiff if you do. adjust left side first.. then right side. post back with details on the 1st question before adjusting the sector studs. did you adjust the shim stack any? |
| Nilram
02-14-2013 08:02:08
208.123.15.242
Re: NAA steering shaft in reply to soundguy, 02-14-2013 05:20:05
| Soundguy, I must admit that when I took the steering apart I was only interested in getting it working as quick as possible to finish blowing my neighbors driveway out (16" of new stuff). I did aline the front wheels using a tape measure before I opened the sector and they remain the same after I set the gears back in. The steering wheel does not move up or down when when it is turned.I will adjust the sector studs later today and post back. Thanks Nilram |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
