Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: NAA steering shaft
[Show Entire Topic]  [Return to Forum]
soundguy
02-12-2013 05:15:30
184.245.237.11
ditto what john said.
mine on my 8n did that once, and I did repair it. pinned and welded the tube/rod.
the steering box is EZ to take apart.. and on a naa you can cheat and only take the central dash apart and not the entire hood sides.. etc.
[Reply]   [No Email]
Nilram
02-13-2013 16:11:12
208.123.15.242
 Re: NAA steering shaft in reply to soundguy, 02-12-2013 05:15:30
Thanks for the advice on my steering problem. I was able to weld it but on the test run I found that I have 1/3 of a turn of play in the wheel. Is there a way of taking up this much "play" without taking it all apart again? Thanks
[Reply]  [No Email]
soundguy
02-14-2013 05:20:05
107.41.182.34
 Re: NAA steering shaft in reply to Nilram, 02-13-2013 16:11:12
when you had it apart, that was the time to R&R the thrust bearings and adjust the shim stack.
if the steering wheel rises or falls slightly as you turn the wheel lock to lock with the front end jacked up.. you need to repalce those thrust bearings. if no rise / fall, check your sector adjustment.. you can do those externally.. loosent he sector stud lock nuts and then adjust the sector studs in with a large screwdriver till they just snug up.. don't try torquing them.. they will make the steering stiff if you do. adjust left side first.. then right side.
post back with details on the 1st question before adjusting the sector studs.
did you adjust the shim stack any?
[Reply]  [No Email]
Nilram
02-14-2013 08:02:08
208.123.15.242
 Re: NAA steering shaft in reply to soundguy, 02-14-2013 05:20:05
Soundguy, I must admit that when I took the steering apart I was only interested in getting it working as quick as possible to finish blowing my neighbors driveway out (16" of new stuff).
I did aline the front wheels using a tape measure before I opened the sector and they remain the same after I set the gears back in.
The steering wheel does not move up or down when when it is turned.
I will adjust the sector studs later today and post back.
Thanks
Nilram
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
