TractorLinks.com
Order Ford 600 Parts Online
Re: 1957 600 Project - Will not Turn Over
old
02-11-2013 17:58:46
Pull the starter side cable off the solenoid. Now take that and touch the battery side with it.. If it turns over when you do that then you have a bad new solenoid. If it does not turn over check starter ground and if that does not fix it take the starter to an auto parts store and have it checked it maybe bad
TM_1957Ford600
02-16-2013 18:16:32
 Re: 1957 600 Project - Will not Turn Over in reply to old, 02-11-2013 17:58:46
Well got her running after about 15 years! Thanks for the help everyone!
Dave in MS
02-17-2013 15:59:34
 Re: 1957 600 Project - Will not Turn Over in reply to TM_1957Ford600, 02-16-2013 18:16:32
So what did you that got it going?
TM_57Ford600
02-17-2013 16:10:24
 Re: 1957 600 Project - Will not Turn Over in reply to Dave in MS, 02-17-2013 15:59:34
First thing was that I bought a new (bad) solenoid
Then I called OLD and he helped me diagnose some small electrical issues. I was able to get the starter to hit and it acted like it was in a bind. I pulled started and confirmed that it was working.
The next thing I tried was turning over the motor manually with the plugs out. I was able to turn it over so far in one direction before it stopped, same with the other direction. I new this was not right so I kept working it by turning the motor over by grabbing the fan.
Finally a bunch of old gunk shot out of #3 plug and it began to spin freely! Bolt starter and carb up and after adjusting on carb it hit and ran.
Dave in MS
02-18-2013 08:24:19
 Re: 1957 600 Project - Will not Turn Over in reply to TM_57Ford600, 02-17-2013 16:10:24
Glad you got it running. We all owe "Old".
