Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 5000 Parts Online
Re: Ford 5000 diesel. What oil?
David G
02-11-2013 14:33:46
Rotella is fine, just pulled a diesel apart with 7000 hours on it, zero sludge, do not believe the wives tails.
Larry NCKS
02-11-2013 15:57:58
 Re: Ford 5000 diesel. What oil? in reply to David G, 02-11-2013 14:33:46
7000 hours????? That's not a very good recommendation for Rotella!
I have a firend that's got 33,000 hours on a 706 Farmall diesel. He claims he's overhauled at about 11,000 hour intervals on straight weight oils that were not Rotella!
Sean in PA
02-12-2013 04:02:07
 Re: Ford 5000 diesel. What oil? in reply to Larry NCKS, 02-11-2013 15:57:58
He did not say why he had to tear apart the engine. It could have been from cavitation or head gasket, or a number of things not related to lubrication issues.
RodInNS
02-11-2013 17:51:37
For the less informed... why don't you state who's produce YOU are selling...
Rod
Brian in MA
02-12-2013 08:59:06
 Re: Ford 5000 diesel. What oil? in reply to RodInNS, 02-11-2013 17:51:37
OK, I'm a little less concerned about the fact that I have been using Rotella without incident for many years now. Honestly, I doubt that I put more than 200 hours on any piece of equipment between oil changes, so I feel pretty good.
RodInNS
02-12-2013 09:50:22
 Re: Ford 5000 diesel. What oil? in reply to Brian in MA, 02-12-2013 08:59:06
The way I had it put to me one day... and I forget who said it... but his remark was that Rotella was a modest quality oil with a top notch marketing program and a top shelf price.
That still doesn't mean it's a bad oil...
I've never used it myself. I've never heard anything bad about it either... so I'd say if it works fine for you; use it.
Biggest thing in avoiding wear is to avoid hard cold starts and keep the oil and filter changed within the manufacturers recomendations... or when you notice oil degredation.
I have one I change at 100 hours use though it's recomended at 150 hours... but basically it starts slowly consuming oil around 70-80 hours use on hard work... oil is degrading abit... so I change it when it gets down to the add mark.. unless it's really low hours since the last change.
Rod
