TractorLinks.com
Order Ford 5000 Parts Online
Re: 5000D gen
Ed1
02-10-2013 17:16:02
I appreciate all of you guys input! The battery is only about 6 months old, it did the same thing to the previous battery. Also when I put my first gen and volt reg (I owned the tractor for 9 yrs.) I put a new harness on the tractor. I will take the gen and have it checked and see how many amps it is putting out.
Thanks again,
Ed1
RodInNS
02-10-2013 18:31:24
 Re: 5000D gen in reply to Ed1, 02-10-2013 17:16:02
What you need to do is put a voltmeter on it and see what it's putting out for voltage at rated speed... and check it again in 10 min, 30, min 60 min and see what it's doing then... with the engine running at mid speed or more. If a battery is low it will take time for the voltage to build up. Once it reaches charge then it will climb until it boils...
You've got 14.4V so you know the gen is working fine. What you don't know is wether or not the regulator is A. limiting current, B. Limiting maximum voltage or C. wether or not the cutout is working.
I'd be inclined to suspect that the cutout is simply not working on the reg... contacts welded shut, etc.
It could also be a wiring problem that is not allowing the reg to correctly sense the charge voltage..
First step is to accurately find out what voltage is reaching the battery over a period of time... then you know where to start looking.
Rod
