TractorLinks.com
Order Ford 5000 Parts Online
Re: 5000D gen
Ultradog MN
02-10-2013 15:18:00
I always respect Rick and Soundguy's advice here.
But another thought would be to ask how old is your tach cluster. Do the tach, hour meter, fuel and temp gauges still work.
Those clusters were known for their early failure.
So, because you have a late style block it would not be hard to convert the tach drive to the 5600 style which is driven off the cam under the oil filter.
Then you could use an inexpensive 10SI alternator and have all working gauges plus a reliable/new cluster again - all for about the same price as that alternator with the drive on it.
RickB
02-10-2013 15:57:19
 Re: 5000D gen in reply to Ultradog MN, 02-10-2013 15:18:00
All true, Jerry. But the charge rate seems normal. An alternator conversion might not accomplish anything.
We need to be sure there isn't a different underlying reason for the boiling battery.
Ultradog MN
02-10-2013 20:03:11
 Re: 5000D gen in reply to RickB, 02-10-2013 15:57:19
Small potatos here but...
He made a couple of comments/statements about his charging system.
Then he said he was thinking about buying an alternator with the tach drive and asked a question about them.
You went into his charging problems.
I went into the merits of the alternator with the tach drive vs a whole new tach, tach drive and cheaper alternator.
Did I not address his question?
RickB
02-11-2013 02:45:44
 Re: 5000D gen in reply to Ultradog MN, 02-10-2013 20:03:11
"Did I not address his question?"
Actually, I don't think you did.
I just happen to think that advocating an alternator conversion on the basis of a 14.4V charging rate and a boiling battery might not accomplish much. I am an advocate of troubleshooting before investing, not troubleshooting after the investment doesn't yield results. If you disagree, that's OK.
