Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Ford 1710 PTO
[Return to Forum]
lonnie77
02-10-2013 14:51:24
99.101.123.152
I have a problem with the pto not staying engaged. I replaced the bearing and seal, everything went back together fine. With the engine off the pto shaft will turn either direction. I can engage the pto and turn the shaft only one direction. Then start the engine with it engaged and it will work for about 5-10 minutes. The pto will handle is still up and if I disengage the clutch and try to engage the pto and it will barely engage and then pop out. If I lift the mower the pto will engage and stay engage. There is no movement back and forth with the shaft and about a 1/32 movement up and down.
It is a Diesel 12/4 gear 2wd synchro. The pto speed is set by the rpm I don’t know if that’s multispeed. I have a service manual and I cannot find anything on this type of problem. The shaft slide’s in with a slight turn and fits into a pilot bearing it the rear. Can anyone help me with this?
[Reply]   [No Email]
lonnie77
02-14-2013 16:12:27
99.115.52.45
Re: Ford 1710 PTO in reply to lonnie77, 02-10-2013 14:51:24
Ok found the problem. There is a spacer on the end of the PTO shaft that will fall off when removing the shaft. The upper case under the seat has to be removed to install the spacer. Removing the upper case is not hard to do it's just there are several bolts and nuts holding it it place.
http://www.flickr.com/photos/lonnie7777/8474979252/in/set-72157631007850388
http://www.flickr.com/photos/lonnie7777/8473926203/in/set-72157631007850388
  [Reply]  [No Email]
soundguy
02-10-2013 14:55:38
107.41.153.148
i'd check the engagement collar and fork and make sure it is actually fully engaging the pto..if there is a detent, and I imagine there would be.. check that as well.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
