old your opinion
POPGUN
Hey old find heybusdrivers post: 'Need expert advice?' below and chime in. I know if anybody knows how to solve his broken stud problem you and Zane would have good advice. Thanks Im also interested.
I looked at it but he seems to have had a good number of answers to it. Me on one like that I would sue one of my easy outs but I do not have the cheap hardware store easy outs my set cost me $75 about 20 years ago and in that time only had one brake
(quoted from post at 18:24:35 02/09/13) Left handed drill bit maybe, but the easy out usually isnt easyout. Dont use it!
Right! Easy Outs are not easy, extractors work much better.
As normal your only right some times. I have a set of easy out or extractors that work well but they are not cheap is in a set cost $75 20 years ago. In that time I have broken only one. I do not and will never say to use a cheap hardware store easy out but the set I use works 90% of the time and when it doesn't well then your going to have to heat weld or some other such
That all depends on if you buy the cheap hardware store easy outs or if you buy a good set. I have a good set in in the 20 plus years I have had it only broken one and it was the next to the smallest one but the set is not cheap. Last I checked to buy a set of them was over $100
