| Ford Tractors Discussion Forum |
Topic: No oil pressure Ford 5000
[Return to Forum]
| Author |
[Modern View]
| Dave In Chattaroy
02-09-2013 14:38:06
204.9.111.230
I need some input from you guys. I had posted a while back about the oil pressure light on my ’72 Ford 5000 (diesel w/SOS) coming on and staying on.
I have owned this tractor for about 6 years and use it primarily for stacking and feeding round bales with the Ford high lift loader that’s on it,
so I need to minimize my downtime.
From what I’ve been able to gather possible causes could be, faulty pump, faulty relief valve, broken/worn pump shaft, or bearings out tolerance.
I replaced the oil pressure switch and verified the wiring and operation. I also replaced it w/an analog guage that confirmed no oil pressure.
Some of you suggested that I pull the soft plug and ensure that the oil pump gear was engaging …..it is. Next I pulled the oil pan and replaced the oil pump with a new one, I also cleaned and inspected the sump for shavings and didn’t really find anything alarming. I was told that damaged main bearings would be pretty obvious with residue in the pan. With the oil filter removed oil does get pumped out of the oil supply. Next I pulled the valve cove to see if any oil at all was making it to the top of the motor..….started the tractor, pretty much nothing up top.
So here’s where I’m at today, I suspect possibly the camshaft bearings are done or I have a plugged oil gallery somewhere. I’m about ready to pull the motor and either have it rebuilt or buy a remanufactured long block.
Before I do this am I missing anything???? Any last troubleshooting????
As always I appreciate your suggestions and advice. :?:
Dave |
[Reply] [No Email] | |
| Dave In Chattaroy
02-10-2013 15:15:42
204.9.111.230
Re: No oil pressure Ford 5000 in reply to Dave In Chattaroy, 02-09-2013 14:38:06
| jkies- after I replaced the oil pump and reassembled the tractor, when I started the tractor the oil pressure light was out initially.....and stayed out for about 5 minutes then came back on.......granted I had just refilled the oil and the barn temperature was in the teens.......
Bern- thanks for the info, Is the front cup accessible by removing the front engine cover? |
| Bern
02-10-2013 21:16:25
66.218.203.127
Re: No oil pressure Ford 5000 in reply to Dave In Chattaroy, 02-10-2013 15:15:42
| Yes, the cup plug in question is behind the camshaft gear. |
| Dave In Chattaroy
02-11-2013 10:20:29
70.89.143.21
Re: No oil pressure Ford 5000 in reply to Bern, 02-10-2013 21:16:25
| Well since I've got to tear the front end off the tractor anyway to pull the motor and/or drop the sump....I'll now be checking that front cup as well!....thanks for the tip! |
| jkies
02-10-2013 14:21:31
208.126.102.238
| worn bearings normally show good oil pressure at start up then less as engine warms up. some times heavier old will help. if this happened all at once then it's probably something else. |
| Bern
02-10-2013 12:09:46
66.218.202.199
| | So, if I understand you correctly, you have ZERO oil pressure, and yet there is oil coming from the pump at the filter location. Am I understanding you correctly? If that is the case, then you have a MASSIVE internal leak somewhere, way more than worn bearings. Possible areas include a missing cup plug in the front, and the threaded plug in the rear of the oil gallery. Other possibilities inlcude a crack somewhere along a major oil gallery, but I would be at a loss to suggest where. As for your theory of a plug somewhere, I really, really doubt that, unless someone injected super glue into your engine. I have rebuilt literally dozens of those engines, and have never heard of a problem like that. I consider those lube systems to be fairly bullet proof. |
| Dave In Chattaroy
02-10-2013 09:16:39
204.9.111.230
| Showcrop, I must have missed that suggestion but let me ask the question because I'm not familiar with the plastiguage measuring.....if either the mains or the rods are out of tolerance, I'm still looking at a rebuild correct? at least on the lower end?
Ultradog, there was no oil in the radiator
The cavitation that you're refering to, I'm assuming that it would cause a comprimise in the blocks integrity? I guess the idea of fixing a hole in the block would probably drive me towards a fully remanufactured engine. I'm looking for some longevity for the amount of effort involved in the R&R of this engine!
Thanks guys. |
| showcrop
02-10-2013 10:24:51
75.67.231.80
Re: No oil pressure Ford 5000 in reply to Dave In Chattaroy, 02-10-2013 09:16:39
| Quoting Removed, click Modern View to see
If you find one main is way out that tells you that all plus the rods are in need of replacement. You should be able to replace all except the rear main, (depending on the type of cap it has) from underneath without removing the motor or splitting. A split is required to do the rear main properly although it can be done without splitting with liberal application of RTV silicone. BTDT. This should get you many more years. If you find that the bearings are good you need to look deeper. |
| showcrop
02-09-2013 17:35:08
75.67.231.80
| I'm pretty sure that I suggested to you before that while you have the pan down to remove one main bearing cap and plastigage to measure clearance to see how far out you are. Rods wear more than mains but it will still give you an idea. It takes just a few minutes with the pan off. |
| Ultradog MN
02-09-2013 15:35:17
174.30.216.68
| In addition to cavitation problems in the cylinder walls those engines will also cavitate into the main oil line. Any oil in the radiator? Not sure about this but I would drop the pan again and hook an air line up to where the sender screws into the block. Pressurize it to about 70 psi and see if you can find any obvious hissing. It will hiss some from all the bearings but there might be one obvious hole. You might rotate the crank a bit to line up the ports in the crank as I think it will fluctuate from zero to 60 psi as the crank turns and the holes line up. There is an old school machinest here who has fixed a bunch of those 3/4/6 cyl oil lines that cavitated by using a reamer and then epoxying in a piece of brake line. Not sure where it cavitates but he explained the process to me once. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
