Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 5000 Parts Online
Re: 5000 ford diesel 4.4 inch bore early block
randyc1983
02-09-2013 12:14:20
Lets try this. Lol. Fun. Head gasket 87800517 is what the book says fits. The pattern and shape of the push rod openings, oil gallery and water passages are completely wrong. The bore size is right.
Head gasket 82845203 fits earlier model tractor with 4.2 bore. The pattern of the surrounding openings matches my block but the fire rings stick out over the piston.
My old head gasket. With no number anywhere to be found matches everything great. It worked. I need a new one. Lol.
I have numbers off of the block. Unit numbers for the tractor and will try attaching these pics so you can see and hopefully someone else can feel as crazy as me.
randyc1983
02-09-2013 12:56:06
 Re: 5000 ford diesel 4.4 inch bore early block in reply to randyc1983, 02-09-2013 12:14:20
The gasket it says i need in the book. Are we having fun yet. Lol.
randyc1983
02-09-2013 12:58:53
 Re: 5000 ford diesel 4.4 inch bore early block in reply to randyc1983, 02-09-2013 12:56:06
The front of the gasket that its supposed to use.
Bern
02-09-2013 18:15:16
 Re: 5000 ford diesel 4.4 inch bore early block in reply to randyc1983, 02-09-2013 12:58:53
Can you send a pic of the old one next to the new one? Or the new one next to the block? It looks close to me.
randyc1983
02-09-2013 18:58:52
 Re: 5000 ford diesel 4.4 inch bore early block in reply to Bern, 02-09-2013 18:15:16
I took all the new ones back. All i have right now is the old one.
randyc1983
02-09-2013 12:50:26
My old head gasket. The calipers say 4.520. The front is to the top. The hole up front. Top left is the first place its different on the newer gasket. The holes along the left side are all a little different on the newer gasket. Most of the rest are pretty close.
Bern
02-09-2013 12:39:31
Do you have a pic of the 87800517 head gasket? If it's as wrong as you say it is, then I am guessing it was mis-packaged.
randyc1983
02-09-2013 12:37:57
The tag under hood.
randyc1983
02-09-2013 12:32:20
The top view of the block
randyc1983
02-09-2013 13:27:51
 Re: 5000 ford diesel 4.4 inch bore early block in reply to randyc1983, 02-09-2013 12:32:20
The block. There is a date code i believe you can see, 8d27. By the way they explain it to me the 8 means 1968. The second letter is a d which means april and the last two are 27 which was the day of the month. April 27th 1968. So i am at the end of my rope. It doesnt match the book and the two numbers i have tried dont fit.
randyc1983
02-09-2013 13:33:10
 Re: 5000 ford diesel 4.4 inch bore early block in reply to randyc1983, 02-09-2013 13:27:51
Why dont they give me the number. Err.
randyc1983
02-09-2013 13:43:02
 Re: 5000 ford diesel 4.4 inch bore early block in reply to randyc1983, 02-09-2013 13:33:10
I found one of these on ebay. Maybe it will fit.
