Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 6 volt ammeter driving me nuts
[Show Entire Topic]  [Return to Forum]
John in la
02-09-2013 05:55:32
184.38.236.37
I agree with JMOR
If you get voltage at amp meter with key on and no voltage with key off you have it wired wrong. What has happened is you are running all the charging system threw the key switch and it is about to fail. These key switches are for very small loads and they still fail often.
If after checking out your tractor you find we are correct I would replace the key switch even if it still seems to be working properly.
[Reply]   [No Email]
Phil960
02-09-2013 07:29:12
173.30.173.190
 Re: 6 volt ammeter driving me nuts in reply to John in la, 02-09-2013 05:55:32
Ok, so the wiring is wired wrong, but where? I've had this particular tractor only 2 months and the only wiring I've changed is the ammeter itself. When I got it, the ammeter was broken and it was the original solid wire through the loop type. I did have to replace the key switch but wired it exactly as the previous one. The previous owner used the tractor on a daily basis and did not reveal any problems which of course doesn't mean much. The wiring appears original but who knows? I'd like to get this figured out before spring as this tractor is to be a working tractor. I have used it quite a bit already and most other issues have been resolved. I really hate to start throwing parts at it without knowing what is really going on. Thanks for the input. I will start a complete wiring check later today and let you know what I find. Thanks again.
[Reply]  [No Email]
John in la
02-09-2013 09:05:28
184.38.236.37
 Re: 6 volt ammeter driving me nuts in reply to Phil960, 02-09-2013 07:29:12
While it is easy for us to pick out why you have a problem it is often hard for us to tell you the real problem since we can not see the tractor.
With the way I have seen some people wire these tractors I am only guessing. That is why I give you a diagram. You could be using the amp meter; key switch; or even a terminal block to connect wires. All will give differant problems and will change my answer.
BUT................
Lets assume we are using all the stock parts and go from there. You can see there is a wire (yellow if orginal) that runs from the starter relay to the amp gauge. This will give the amp gauge power 24/7 and you said no power with key off. Hence we know you have it wired wrong.
How it is done is the question.
You could have the wire from the relay direct to the terminal block A side and the amp gauge voltage regulator to terminal block B side. This will cause all power to run threw the key switch.
Another way of saying this is......
Look at the terminal block in the picture. The top bolt is hot 24/7 It has one side of the key; power from the battery threw the amp gauge; and the voltage regulator B post.
The other side of the terminal block only has power with the key on. It has the key switch and coil only. So the only power that is switched by the key is the coil.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
