Yesterday's Tractor Co.
Shop Now View Cart
Order Ford NAA Parts Online
Re: jubilee hydr. lift problems
George Marsh
02-08-2013 16:49:23
I would say your control rod isn't adjusted properly. If it were, when the hyd piston started coming out too far, it would stop the upward motionn not act like it still wants to go up.
Get a manual and put it back in adjustment. It took me 4 times removing the lift cover to figure out how to get it right. My linkage was worn so much, it was difficult to get it close to working properly. So I came up with my own way of ajusting it, moving my lift arms and making sure the control rod was 1/4 inch out before my lift arms were all the way up.
Buy many spare lift cover gaskets.
02-08-2013 17:13:04
 Re: jubilee hydr. lift problems in reply to George Marsh, 02-08-2013 16:49:23
it does seem like it is adjustment and i will move it around in the morning.i just dont understand how it worked okay until i pulled the cover went up and down fine just a little jerky.i dont have a manuel handy and need to get it working it does have any pressure at all when i turn it off.
Bill Rowles
02-08-2013 23:24:05
 Re: jubilee hydr. lift problems in reply to mcinville, 02-08-2013 17:13:04
If you don't have a shop manual, I think you better take the lift cover to someone who knows how to adjust the linkage. I have a minor problem with my NAA hydraulic control, I bought the manual, and I have been studying the mechanism for months before I attempt to tinker with it. General knowledge of how to repair mechanical things is not enough to be successful in this case. Knowledge and experience are the only solution to your problem and it sounds like you need to get help to correct it.
George Marsh
02-09-2013 04:49:02
 Re: jubilee hydr. lift problems in reply to Bill Rowles, 02-08-2013 23:24:05
The linkage on my Jubilee is so slopy, worn, that the next time I take it apart, I'm going to ream out the piviot points and make a bushing to fit. Try to make the round places round again.
I also made a 1/2 inch drift pin to help bring my adjustments close enough to work.
Face it, 60 years of wear and rust created by no vent in case, takes it toll.
I also had to rebuilt my pump and installed a pressure guage. It's possible there are more than adjustment problems here.
