TractorLinks.com
Order Ford 5000 Parts Online
Re: 5000 seems to be slipping
Chris in SK
02-06-2013 18:04:58
Assuming it's an manual trans and not a select-o-speed, and the clutch is slipping? Is the clutch adjusted correctly with about 1.5" - 2" of free play at the top of the pedal? If it is, your clutch is probably worn out.
Chris
Ted E.Bear
02-06-2013 18:27:31
 Re: 5000 seems to be slipping in reply to Chris in SK, 02-06-2013 18:04:58
thanks for the reply chris, yes its 8sp, and no free play in clutch pedal, when i put a load to it on any kind of incline it stopps, when i clutch it i can feel the clutch enguage and dis enguage, then i have to go to first gear and crawl till i get on level ground b4 upshifting
Larry NCKS
02-06-2013 19:03:42
 Re: 5000 seems to be slipping in reply to Ted E.Bear, 02-06-2013 18:27:31
At a bare minimum you need a clutch adjustment. Not sure what the free play is on that unit, but would guess it to be around 1 inches.
If it can't be adjusted to provide proper operation, you'll need to rebuild your clutch.
Ted E.Bear
02-06-2013 21:36:32
 Re: 5000 seems to be slipping in reply to Larry NCKS, 02-06-2013 19:03:42
thanks for the reply larry, i was kinda thinking i was going to need a clutch job,
