Ultradog MN
- Location
- Twin Cities
FordFarmer steered me onto about a 66 4000 with a bad SOS to be auctioned.
We have a 3000 6 speed tranny/rear end here that we can't seem to sell.
So I was wondering about dropping it in place of that bad SOS.
I know the output shaft on a 3000 would be slower as the rear end is only single reduction.
I'm wondering how much slower.
Would a guy have a tractor that would run 8-9 miles an hour? Or would it be slower than that?
I think a slow tractor would still have some value for draft work, etc. But if it would only go 4-5 miles an hour that would be no good.
Where would a guy look to compare those output ratios?
We do have the 3000 flywheel and single clutch to go with the 6 speed. Anyone know if the 3000 splined coupler would fit on the SOS pinion shaft? Could cut and weld that too I guess.
What other surprises would a guy find?
PTO shaft too short?
I know it's kind of a Jerry Rig deal but if a guy could make the old tractor be productive again it might be worth while.
Just reuse the side pump and lines from the SOS.
Any thoughts on this?
Thanks
Thanks
