19-209 loader
Would help if you gave us the model of tractor it's going on.
<a href="http://www.google.com/search?hl=en&as_q=19-209+loader&as_epq=&as_oq=&as_eq=&as_nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_sitesearch=&as_occt=&safe=off&as_filetype=&as_rights=not+filtered+by+license" target="_blank">Google is your friend for stuff like this.</a>
Looks like you have a one armed loader that you are wanting to mount on a 4 cyl tractor.
That front bracket is a very simple bracket that could easily be torched out of a piece of 1/2" plate.
Thanks to soundguy for this photo.
The one on the right in the photo.
If Ultradog Doesn't have a set of conventional brackets off the tractor I do. I hope you have the right trans bracket for the right box.
Kirk
I probably have the tracings on paper already.
I do this from time to time for people making brackets.
as UD said.
1/2" plate is fine for torching the front.
the lower strap that goes from the foot over to the underside of the trans can also be torched out of plate.. but 3/8 is fine for the main strap and 1/4 for the lil tie strap.
i'll check when get home.. but am almost certain I saw the last set of papers from one I traced a few weeks ago.
well, the trans bracket is the IMPORTANT one.
the lower straps and front hanger are all torchable as UD said.
Chris,
He emailed me and I sent him the drawings this morning including the bracket with the countersunk holes.
Kirk
