Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4000 Parts Online
Re: 1964 Ford 4000 Power Sterring
Ultradog MN
01-29-2013 16:08:04
Kurt,
FWIW, the PS on all the ag style 4 cylinder tractors is identical.
Also, the 3 cyl ag models (with wishbone front end) is almost identical.
Both series share the same springs, plungers, upper and lower thrust bearings, spring washer and seals in the hyd block. The cylinders are the same too.
In fact, with a very slight rebending of the inlet and outlet lines to the pump a 4 cyl hyd block would work on a 3 cyl and vice versa.
Both series share the same sectors, bushings and seals in the bottom end too. Probably lower steering shaft bearing too.
