Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 1964 Ford 4000 Power Sterring
[Show Entire Topic]  [Return to Forum]
Kurt-NEPA
01-29-2013 04:11:37
70.44.245.96
I'm not a thousand series guy, but this is what I would do on my 660. I think the systems are similar.
Disconnect the cylinders at the front and try the steering with the tractor running. Do the cylinders work properly and evenly? This might give you a clue.
My 660 had similar problem. One of the springs that operates one of the plungers inside the control valve was broken. Easy fix once the sheet metal is off. The test for this, at least on a hundred series, With the tractor off, move the steering wheel to the left about 2 inches, release the wheel and it should be pushed back to the center position by the springs. Do that again to the right and it should push back to the center. Easy test, if it does not spring back, you have valve problems. A broken spring is also evidenced by erratic motion of the disconnected cylinders.
If the 4000 system is different, forgive my ignorance.
[Reply]   [No Email]
Ultradog MN
01-29-2013 16:08:04
174.20.236.172
 Re: 1964 Ford 4000 Power Sterring in reply to Kurt-NEPA, 01-29-2013 04:11:37
Kurt,
FWIW, the PS on all the ag style 4 cylinder tractors is identical.
Also, the 3 cyl ag models (with wishbone front end) is almost identical.
Both series share the same springs, plungers, upper and lower thrust bearings, spring washer and seals in the hyd block. The cylinders are the same too.
In fact, with a very slight rebending of the inlet and outlet lines to the pump a 4 cyl hyd block would work on a 3 cyl and vice versa.
Both series share the same sectors, bushings and seals in the bottom end too. Probably lower steering shaft bearing too.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
