Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 2600 Parts Online
Re: 2600 loader trouble
Sean in PA
01-28-2013 08:28:14
With the hydraulic filter back next to the pump and the crankcase oil filter, that means that you should have the engine mounted gear driven pump. You may have second filter, but if you do it would be on the return line inside the rear end, and you would have to pull the top cover to replace it, but if you have one, and if it is clogged, it shouldn't cause any problems with pressure or flow at the top plate, as it is on the return line and it has a pressure relief bypass valve to allow the return flow to bypass the filter if it gets too clogged.
whitetail1
01-28-2013 09:08:54
 Re: 2600 loader trouble in reply to Sean in PA, 01-28-2013 08:28:14
i do have the engine mounted hydraulic pump as you mentioned.
Do you think the converter itself could be clogged? should i take it off? is there any danger to removing it ? I do not want to simply remove the 4 bolts to lift it up only to find i dissembled it wrong and it falls all apart.
Copyright © 1997-2015 Yesterday's Tractor Co.
