TractorLinks.com
Show Parts for Model:
Re: 1310 Compact Tractor Gov. Adjustment Not In Manual
eye4iron
01-28-2013 06:45:15
Thanks for the replies. The more I studied the govenor I relized the top screw is for setting the high idle rpm. The bottom short screw is for the internal govenor stop. The top screw has a stiff compression spring on the end of it that pushes on the internal govenor linkage to make the govenor spring tenioner stiffer or loser. The problem that I have is the top screw spring is shorter than it should be and the engine would not throttle up. Had I known this I would not have removed the front cover for inspection and repairs. All I need to do now is reassmble and set the high RPM.
