TractorLinks.com
Show Parts for Model:
Re: 7710 pto clutch wear
dieselpup
01-27-2013 05:02:00
I'm leaning toward replacing the entire assembly. I can see a slightly different color in the metal but can't find a seam where the band would be split. The thought was that even if i could get it out, the sealing surfaces would likely be damaged. Lathe is a good idea. I only have a milling machine but could go over to the neighbors. Parting off or grooving tool would tell the tale. Should've added this is an English tractor. Would that make any difference?
Bern
01-27-2013 06:12:39
 Re: 7710 pto clutch wear in reply to dieselpup, 01-27-2013 05:02:00
From your pic it would appear something is there. If you're leaning towards replacing the drum anyway, put it in the lathe and see if you can dig it out. You may be able to clean it up easier than you think. You also might lean towards doing this after you find out how much a new housing is.
I don't think machines built in England were any different in this area.
dieselpup
01-28-2013 05:12:57
 Re: 7710 pto clutch wear in reply to Bern, 01-27-2013 06:12:39
Three seal rings. I looked it over again until I found what looked like the ring gap. Took a tiny punch and got the ring to move. Running against the support has rolled a burr in on top of the ring. I agree that it can likely be polished. Will price out parts and see. Clutch discs look good. Center bushing looks a little rough.
