Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Shifter seal fluid blowby
soundguy
01-26-2013 18:50:05
ford decided to run suction and pressure lines thru the trans.
now.. if yours is a hyd delete machine.. that simplifies things.
you should have told us these pertinant details up front instead of making us guess.
start over and give a full accounting of the issue
Oaf
01-26-2013 19:13:12
 Re: Shifter seal fluid blowby in reply to soundguy, 01-26-2013 18:50:05
Save the scolding tone for your morning coffee crew. I don't know what's pertinent until you ask. That's why I'm here! :)
Everything's as I said above. Fluid coming out the shifter tube. Pressure builds in hyd and trans cases. Fluid levels topped off, with no apparent change, but I'll check again to be sure. No external hyd parts because of the backhoe. I'll see if there are internals.
Why would hydraulics be run through the tran case? Just to avoid ext piping? Odd...
soundguy
01-26-2013 19:18:26
 Re: Shifter seal fluid blowby in reply to Oaf, 01-26-2013 19:13:12
save the what?
fix it yerself. I'll no longer read / respond to messages with your user title or your IP adress.
later.
have a good day
Oaf
01-26-2013 19:44:25
 Re: Shifter seal fluid blowby in reply to soundguy, 01-26-2013 19:18:26
"you should have told us these pertinant details up front instead of making us guess."
Come on SG, was this really necessary? My intention was obviously not to make you guess at anything. Not a game, just some friendly questions from someone trying to learn.
OK, you're upset at my joke, I get it. Some folks here are happy to toss it out but have pretty thin skins. Thanks for the prior assistance and best of luck to you.
o
