TractorLinks.com
Show Parts for Model:
Re: intermittent stalling/dying
old
01-24-2013 12:36:07
I would start by hot wiring it. As in run a wire from the ignition side of the battery to the coil and start it up. If it runs fine then the problem is from the coil back to the battery and a bad switch can do what your saying it is doing. If that does not work check spark and make sure it is a good blue/white and jumps a 1/4 inch gap the moment it dies. If that is ok them pull the carb drain plug and let the gas flow for a few minutes. Catch it so as to check for dirt water etc.
Phil960
01-24-2013 12:42:49
 Re: intermittent stalling/dying in reply to old, 01-24-2013 12:36:07
Thanks old, I will take those steps in order and report back what I find.
