Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4000 Parts Online
Re: 4000 Shuts down while driving
Al Baker
01-23-2013 11:37:43
Sounds like you have some type of return line restection. On the cav or roosa pump a slight plug will cause the plungers to equalize their pressure on both sides causing them to not pump. loosen the return line where it comes out of the pump and let it leak. See if this allows it to stay alive. If so then you know there is a pressure build up. If you have the simms inline pump then you are starving the pump for fuel.Check for fuel suppy at the fitting going into the pump head. You should have a good steady stream of fuel. I own a small pump shop, and have been inside of hundreds of these pumps. I dont charge anything for over the phone advice. Give me a call and I will help walk you through your problem and get you back up and running 231/757/0064 Ask for Al
Copyright © 1997-2015 Yesterday's Tractor Co.
