Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 201 gas vs diesel
[Return to Forum]
Ultradog MN
01-22-2013 05:38:16
184.100.109.75
Were the gassers subject to the same cavitation/porosity problems as the diesels were?
I've read lots of posts about cavitation in diesels but never once about it in a gasser.
Kenny just found out he has the dreaded cylinder wall rust-through on that junky 4600 he's working on.
We were thinking it would be cheaper to use a gas block that I have rather than the expense of having it sleeved.
Thanks
[Reply]   [No Email]
Ultradog MN
01-23-2013 19:30:06
184.100.109.75
 Re: 201 gas vs diesel in reply to Ultradog MN, 01-22-2013 05:38:16
Thanks fellows.
I think he's going to bore and sleeve the block he has. Mainly because the block I have is the old style with the screw in plugs.
Means he'd have to go back to a generator to run the tach.
I have a set of NOS sleeves he's going to use.
I also have an NOS 4600 head he's going to take.
Going to trade me for his old head.
Such a deal.
I think I'll go to bed now and cry.
[Reply]  [No Email]
Jerry/MT
01-22-2013 12:58:16
206.183.116.145
The initial combustion pressure rise due to compression ignition is more like "knock" in a gas engine and so that"s why the problem occurs.
[Reply]  [No Email]
soundguy
01-22-2013 12:15:43
173.105.127.170
i've also hear leass/no issue with gassers.. however I still run the DCA addatives in my gassers.
[Reply]  [No Email]
Paul in MN
01-22-2013 09:58:33
174.20.128.5
I've paid mild attention to this topic for a number of years as I have 3 401 6 cylinder diesels plus Ford Powerstroke PU engines (none of which have showed this problem). The industry sources say the cavitation is due to the high level of diesel "ping" as it fires under load. This ping sets up the coolant touching the cylinder side into small bubbles. As the bubbles burst, the coolant slams back into the void and slams the cylinder sidewall hard enough to create the erosion. In the Powerstroke engines this can be greately reduced by using the Ford coolant additive. I think it acts like a soap keeping the coolant "wetter". Ford formulated a yellow color antifreeze with the same properties, so it does not need the additive. This same type of cavitation occurs in other brand tractor and truck diesel engines and is dealt with in a variety of methods.
Our gasoline engines have never had any significant problem with these issues, as their combustion is more of a "woosh" than a "bang". Antifreeze formulated for big truck engines is a different chemistry than normal auto antifreeze. It does not have the silicates that auto antifreeze has.
As to the interchangability of the gasser block and the diesel block, I have no real knowledge, but I'd sure have my doubts.
Paul in MN
[Reply]  [No Email]
RodInNS
01-22-2013 07:10:38
216.118.158.123
I'd check the parts book and make sure the blocks are identical. I think they are... but check.
Rod
[Reply]  [No Email]
Dean
01-22-2013 06:31:44
67.172.15.77
AFIK, there is no cavitation issue with the gasoline engines.
Dean
[Reply]  [No Email]
Texasmark1
01-22-2013 06:28:30
198.45.243.137
Don't remember the color, but once I was reading parts lists on tractors and noticed that the bottom end of diesel's was a lot heftier than gas counter parts. One difference I recall is a main for each cylinder whereas the gas only had 3 for the whole engine.
HTH,
Mark
[Reply]  [No Email]
Fordfarmer
01-22-2013 06:17:50
184.158.1.152
AFAIK, the problem is more common in diesels, but the gassers aren't immune. If I understand it right, its more common in the diesels because of the higher combustion pressures, which result in more cylinder wall flex and the resulting cavitation. Using your gasser block will be cheaper IF it doesn't need to be bored out, but beyond that, you won't gain anything.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
