TractorLinks.com
Order Ford 861 Parts Online
Re: 861 Head Gasket Change part 2
old
01-21-2013 10:13:02
On #1 and #4 piston is that just carbon build up on the tops of them or is that pitting?? If it is pitting I would drop the pan and check the rod bearings to make sure it was not run to long with water in the oil
Tom Bond
01-21-2013 10:24:13
 Re: 861 Head Gasket Change part 2 in reply to old, 01-21-2013 10:13:02
It's carbon buildup. The cylinders/head look worse than they are. I put in a couple tablespoons oil in each one for my wet compression test. The coolant in the bolt holes and #2 was me. It spilled in there when I broke the head loose. Cleaning starts tonight.
old
01-21-2013 10:48:10
 Re: 861 Head Gasket Change part 2 in reply to Tom Bond, 01-21-2013 10:24:13
The coolant problem is why you should drain the radiator and also pull the block drain so that is not a problem. Yep learned that one the hard way decades ago my self. I do think if you have a place that would not charge and arm and leg have the head magnifluxed to make sure it has no cracks
