TractorLinks.com
Show Parts for Model:
Re: Compression Test
Tom Bond
01-17-2013 13:17:00
After all the suggestions and odds are, I'll only be using a leak down tester on rare occasions, I decided to save myself about $100 and use SoundGuys idea and build a poor mans tester. I'll just pressurize each cyclinder and diagnose from there. I took a couple different spark plugs and gutted them out, then silver soldered on a male air chuck to each. Added an "O"ring and ready to go. I'll let the air compressor cycle off and bring up the regulator slowly to 100# and listen for leaks or watch for bubbles in the radiator. Here's what they look like.
old
01-17-2013 13:23:56
 Re: Compression Test in reply to Tom Bond, 01-17-2013 13:17:00
Since you plan to pull the head any way you might also pull the valve cover and manifold before you try the leak test. By doing that you may see or hear a leak like that if a cracked head that you might not see or hear other wise
